Now it looks like the rack
charleyk
Wrench Turning Pgmr
Apr 3, 2007
new jersey
Can you believe it? I checked a power steering leak out myself and it looked like it was coming from the pump. I even brought it in to a mechanic who confirmed it. So, I spend a few hours and install the new pump today only to find it still leaking after I'm done. I now find the pass side rack boot is torn and it looks like the fluid is coming out of there. Does it seem possible? Could it shoot up to the bottom of the pump under pressure leading me to think it was the pump?
Thanks....
cuel
1,536
Baytown, Texas
Hmm... dunno if its possible or not, but doubt it. It is possible, however, that they were both bad. I found a good reman'd. rack at a local parts store. Don't remember how much it was, but it was a whole lot cheaper than the dealer.
charleyk
Wrench Turning Pgmr
Apr 3, 2007
new jersey
Is there a seal for the rack inside of the rack and pinion boot on the passenger side? Could that leak and spill transmission fluid through the boot?
cuel
1,536
Baytown, Texas
Yes, there is a seal. No, I don't think you can replace it. I've never tryed, just went and got a remanufactured rack.
charleyk
Wrench Turning Pgmr
Apr 3, 2007
new jersey
Thanks. I'm going to replace the rack. Doesn't look like too bad of a job.
empera
Authorized Vendor
Philly.
is there another type of rack i can use?
I also have a bad rack, leaking out the passenger side boot...bad...
how much for the manufactured rack?
charleyk
Wrench Turning Pgmr
Apr 3, 2007
new jersey
They run from about $150 - $220 with your core. Anything in between seems about right.
