Noise of Cammed 2jz's?
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
Hi guys,
I've just installed some BC 264's in my 2j according to the cam sheet form BC it suggests .006 on intake and .008 on exhuast.. The TSRM however, gives a little breathing room of intake .006-.010 and the exhaust .010-.014.
My question is my cams are noisey at 2000-3000 RPM they are clanking around in side and very noteable to the ear. I had my 1jz cammed before but it was so long ago I can't remember if there was any clanking but I think there was.
On the intake my looses is .008 and on the exhaust the loosest is .010
Here is how they paned out
Intake
1 .007 a .007
2 .008 b .007
3 .007 c .007
4 .006 d .007
5 .007 e .008
6 .006 f .007
Exhaust
1 .009 a .009
2 .010 b .010
3 .009 c .010
4 .008 d .010
5 .009 e .010
6 .009 f .009
How noisy are your cams?
Thanks
Eric, my 1jz cams would sound pretty loud at times when first getting under boost. Since I've put the 1jz head on the 2jz, they seem to have quieted down some.
Do you still have a copy of the camcard for the 1jz cams that you sold? I've got to reshim mine and I'd like to know what clearance they called for. Thanks.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
ive got a copy of the cam card for the small core 272's, ill send it along with the shims jay
Zazzn
7
Toronto/SF Bay area
I believe they are .006 and .008 as well for the crower cams brian always recommends tighter then looser.
how tight did you guys have them hot and henn?
Turbo Drifter
534
Surrey, BC Canada
I installed my HKS cams per the TSRM and cant say if I had any increase in noise just from the cams. I also did Forged CP pistons at the same time and that added to the nose the engine makes as well.
If BC has cam specs for there cams I would follow them.
Jeremy
You sir are going to be receiving a Christmas card from the Hayes Family.......:biglaugh:
Here is what mine are at right now. I'm going to be changing the shims this weekend to correct them.
.......EXHAUST.................INTAKE...........
12......0.0130....................0.007............
11......0.0130....................0.007............
10......0.0140....................0.008............
09......0.0145....................0.008............
08......0.0135....................0.009............
07......0.0135....................0.009............
06......0.0155....................0.011............
05......0.0155....................0.009............
04......0.0140....................0.009............
03......0.0125....................0.009............
02......0.0130....................0.008............
01......0.0120....................0.007............
Zazzn
7
Toronto/SF Bay area
damn supra that's uber loose, i dont know how you didnt shoot a shim.. i did wehn i was 15 thats how I borke the 1jz.
