No turn signals or hazards flashing
maitai69691
280
hilo hawaii
So my turn signals and hazards light up and stay on but no flashing. If manually move the eather switch on/off I can hear the relay click.
I'm thinking bad relay. Also relay is being a PITA to remove will not pull out.
plaaya69
87T Supra
Nov 18, 2006
948
10
Lake County, IL
Sounds like a bad flasher relay. Sometimes you can clean the relay contacts with some rubbing alcohol if you take it apart for a quick fix or buy another.
maitai69691
280
hilo hawaii
I got a good one from my parts car. Problem is the old one won't come out. It should just pull right out but will not budge. I might have to remove the whole thing so I can get it out with out braking any thing.
plaaya69
87T Supra
Nov 18, 2006
948
10
Lake County, IL
You should remove it with the plastic bracket attached so it is easier but I believe there is two white tabs on both sides of the relay.
Mk3TargaJames
10
West Jefferson
This.
I was yanking on my fog light relay to get it out when I had my issues, thought there was only one clip. Eventually found out after frustration and an epiphany lol.
maitai69691
280
hilo hawaii
Got my old flasher relay out and was going to use the one of my 1991 parts car of course it difernt. Well does any one know if a ep33 flasher for a mr2 would work.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,282
73
Atlanta
Did you check the hazard fuse first?
Just thought I'd ask.
If it's actually blown, then the horn wont work either, if I recall correctly.
