no supra at night no tail lights help!!
radicalskater
23
portland tennessee
came home the other night and i had no tail lights of course i checked the fuse of course its fine and power is getting to that point then i changed all the bulbs and cleaned the socket make it nice and clean still no tail lights however the brake light's work blinker's work reverse works need some suggestions can't drive my supra at night now
whitemike
1,164
Winter Park, Florida, United States
Seriously man, learn to use commas and periods. Possibly even capital letters. No this isn't English class, but it makes it a hell of a lot easier for others to read your issue and help you out.
Having said that, check your Lamp Failure Module box.
-Mike
shaeff
Kurt is FTMFW x2!!!!
11
Around
Here's how to fix it:
http://www.supramania.com/forums/showthread.php?t=19859
Aside from the fuse, and pulling the lamp failure module and opening it to look for burned/corroded contacts, check all the wiring in that area. Often times when people take these cars apart they fail to properly re-secure the wiring. On my old black car, such was the case, which ended up chafing the tail light wire on one of the screws back in that area, thus rendering my tails inoperable.
