EDIT: I've left the first posts unedited so you can see where I started, and now where I'm going. After doing some more reading and thinking, I've decided to try and track down the real problem rather than do the relay mod which is essentially a band aid patch fix.
For reference...the mod I'm talking about:
http://www.supramania.com/forums/showthread.php?t=76403
TEWD Starting System Diagram:
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=038
It's got to the point where I'm push starting the car probably once a day on a pretty much brand new starter.
Just have a quick question about wiring this new relay in. I really suck with reaching in to small spaces and have a hard time getting to the starter. My question is do you think it would still cause me problems if I wired in the relay close to the firewall by pulling out the Black/Blue stripe wire out of the bunch in the harness just behind the intake manifold. I pulled the tape off and the wire is easy enough to get to there, but will having the old wire still between the new relay (to be placed between the intake manifold and the master brake cylinder) and the starter still have enough resistance to be causing me issues. I don't want to have to pay other people to do work I know I can do, just I really can't do it easily myself cause my arms are way too big
If anyone else has any suggestions on how to get to the starter wiring easier, I'd be open to suggestions there too.
