hey, would the stock ecu pull timing if it didnt see an o2 sensor?
single guys, how do u run the stock flanged o2 sensor on the downpipe?
Evilempire1.3JZ-GTE said:^^^
I thought though when you run leaner you yield more power but damage the engine more! like melt pistons etc.
jetjock said:How is that correct? 12 to 12.5 is richer, not leaner. Maybe I'm reading something wrong. Best power is always richer than stoich.
As for not surviving airplane engines are routinely run on the lean without problems. And that's at 75% power. WOT is a different story. My point is it's not as black and white as people make it out to be.
boostindoo said:oh another thing im assuming i hooked it up correctly but would like verification.
bosch o2:black signal
white heater no polarity
grey optional ground
stock plug:white signal
black/pink heater +
pink/blue heater -
for the heater wires, i just hooked up whatever because the bosch's didnt have polarity. and i just grounded the ground since i dont have a ground on stock plug. sounds okay guys. thanks.
