I have an aftermarket turbo with no nipple on the housing. The Profec B Spec II manual says I need to have a pressure source for a vac line, suggesting the nipple on the turbo. I thought I could get away with using one of the stock nipples on the intake plenum, but I think I need a better source. I am not getting a boost reading from the EBC either and unsure if this is why. I was wondering if it would be fine putting a nipple in the 3000 pipe as the vac source. I also have an external wastegate if that makes any difference...Can I get some advice on what others have done in the same situation?
Thanks in advance
			Thanks in advance
