no fuel no start
maitai69691
280
hilo hawaii
Ok so i just fininshed a full rebuild every thing pluged in and ENG is in the car put in some fresh gas and see if it fires up crank crank crank and nothing. geting code 22 and 51 posibley need to adjust TPS...
but its not even trying to start so open the fuel sender access panel in the trunk key ON no sound...then i did the bypass trick at the diag port NOTHING no sound from the pump. all fuses are good.
correct me if im wrong: next step check for voltage at the pump.
maitai69691
280
hilo hawaii
ok started checking voltage: at the pump plug 12v with diag port briged but when i plug it into the pump nothing dosent make any noise now im lost...also geting 12v EFI 15amp fise...12v at 7.5 IG fuse...
maitai69691
280
hilo hawaii
well i just disconnected all the pulgs in the fuel pump cercit as was trubleshooting it from begining to end pluging every thing as i went. I one of the connections wasnt on good cause now the pump works got fuel to the injectors. but two injectors are leaking at the rail now i get to pullt it apart YAY...
thanks for all the help...
