No Boost
josh930
247
NY
I recently pulled my engine to change the oil pan and as I was putting everything back together I decided to do the SOGI wastegate mod with 4 washers. Before I did this I was hitting 12lbs of boost with a home made manual boost controller the owner before me installed. Now, my problem is that I am getting no boost and my wideband hits lean. It sounds like fuel cut but I'm not even getting any boost. I checked for boost leaks, but found nothing. Any clue?? I did alot of searching but found nothing like mine. Thanks
Supracentral
12
Check to be sure the line is connected to your fuel pressure regulator. Sounds like your rising rate isn't working.
lcordovagts
Dazed and Confused
Apr 28, 2006
connecticut
sounds like you put too many washers in when you shimmed the wastegate. or you damaged the accuator arm when shimming it i would definetly check the wastegate it its probally stuck wide open and thats probally why your not getting any boost.
