NM Motorsport - The NM Short Shifter is back!
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
Hello all, and welcome back to Supramania!
Nashman and I have built a new batch of the infamous NM Short Shifter, and it's now for sale through our new website: NM Motorsports Canada
Our good friend Paradox even made us a great promo video:
The original short throw shifter with adjustable shift knob position.
The standardized 316 Stainless Steel 1/2" upper rod is threaded M12x1.25 to match the factory shift knob, and you can cut down the length of the shaft if you want it even shorter.
80% shorter shifts! Better shift feel!
New features for V2.5:
  • Captive knuckle fasteners, allowing a wider range of shift knob positioning
  • All yellow zinc fasteners
  • Includes NEW Toyota green truck bushing 33505-35020 (MSRP US$15.37)
  • Includes NEW Toyota white bushing 33548-31010 (MSRP US$6.64)
The shifters are back for sale at CDN$389, and that includes free shipping to anywhere in the continental USA and Canada! You can see what the currency conversion is to USD, Euro, British Pound Sterling, and AUD in the top right corner of the page. Shopify converts the currency to whichever you choose at the current market rates.
We built a batch of 50 shifters, so supply is limited.
________________________________________________________________________________________________________________________________________
We're also working on a bunch of new products for the MK3 Supra and the Toyota Tacoma. All of our parts are designed, tested, and manufactured in Canada and the USA.
Follow us on Facebook for updates as well.
Enraged
24
We now have the 7M Center Valley Cover available!
This cover replaces the stock center valley cover. This new cover is stainless steel, so it will never corrode. Brushed finish.
Includes a 14mm hex bit to remove your stock fasteners.
Fits Toyota 7M-GTE and 7M-GE. Price is $90.00 CAD for the cover, or add our 7M Valve Cover Stud Conversion Kit to your cover order and save 10% on the Stud Kit!
The stock bolts lose tension over time, and you start to get oil leaks from the valve cover gaskets. This stud kit replaces the stock bolts with Class 8.8 DIN 939 yellow zinc plated hardware. The studs hold tension better than bolts, and the nylock nuts won't come loose.
A full set of 12 to replace the fasteners for both valve covers:
  • Yellow zinc plated M6 studs
  • Yellow zinc plated M6 washers
  • Yellow zinc plated M6 Nylock nuts
Fits the 7M-GTE and 7M-GE, $30.00 CAD for the kit, or $27 CAD if you buy it with the Center Valley Cover
  • Like
Reactions: CTsupra
Enraged
24
We're doing a limited time Canada Day discount of 10% off site wide. We need to make some room for new products, so hopefully some of you want a new shifter! Use code CANADADAY2022 in checkout from July 1st to 3rd.
Enraged
24
It's been a minute, time sure flies.
We have some new products on the site, and a few new ones coming soon.
We have one of the proto 10AN fuel rails left. We may do another batch in the future if there is interest: https://nmmotorsportscanada.com/products/10an-fuel-rail-for-7m
We have lots of our simple IS300 Coil Brackets: https://nmmotorsportscanada.com/products/is300-coil-bracket-for-7m
New Blank ECU Plates so you can mount your standalone in place of the stock ECU: https://nmmotorsportscanada.com/products/mkiii-supra-ecu-blank-panel
And for anyone that has a Tacoma, we made a version of the NM Shifter that's compatible with the RA60 and RA61 transmission: https://nmmotorsportscanada.com/products/nm-shifter-v2-5-for-toyota-tacoma
We have some more billet 7M parts coming soon, and some more MKIII Supra brackets too!
Enraged
24
We've got some new parts released for the 7M coolant system.
Our 7M Thermostat Spacer moves the stock thermostat cover away from the engine by 20mm, allowing you to remove your timing cover without draining the coolant system! It moves the thermostat away from the engine and provides two 1/8NPT threaded holes so you can easily add sensors on the engine side of the thermostat, without modifying your stock water neck.
We also have a new 7M Thermostat 20AN Conversion Cover for those of you that are wanting to convert your coolant system hoses over to AN hoses. This is a replacement for the stock cover (and is compatible with our Thermostat Spacer) and provides a -20AN thread in a compact package.
  • Like
Reactions: awsom-0
