newb question
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
whiteturboz89;1042726 said:
if my 1989 turbo supra is burning oil, is it safe to add the fluid treatment that seals up the cylinder walls and rings?
snake oil, it will do more bad than good.
Gilsdorf
Street Dragon
Jun 18, 2005
244
Reno, NV
Have a compression test and a leak-down test done. They will help you diagnose where the burning oil is coming from.
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
NO!!! You have a problem and there are no miricle sloutions. You've gotta think if your sealling your rings other parts of the oil system are going to seal ex. Turbo oil line, oil cooler and line....these products just cause more damage.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
Valve cover gaskets, IIRC, can cause oil to burn on start-up. If it's burning oil while running it can be a number of things... valve train, piston rings, and turbo seals.
A compression test and a leakdown test will tell you about the piston rings. If the turbo has play, it could be the turbo causing the problem.
Nocheez
Probably posts too much
Apr 17, 2005
271
Charlotte, NC
That's a big leak, are you leaving drops anywhere on the concrete after parking? Or is it all being burned? Fix it now, or it'll cost a lot more to fix later.
Gilsdorf
Street Dragon
Jun 18, 2005
244
Reno, NV
When is it burning, acceleration, decel, start-up, all the time? These are clues as to where it could be going.
Check your valve cover screws, they like to losen by themselves.
If you can't find leaks....it's gonna be the valve stem seals or turbo.
My valve stem seals where GONE, the only part left was the metal casing, and the inside of the ports was NASTY.
Needless to say, it ran MUCH better after it was cleaned out and the head was rebuilt...
