new tps still won't run
Tanya
1,851
Naples, FL
TPS' are so damn annoying. If the mkIII ts are anything like mkIIs, you'll have to jump out the check engine connector, turn the key on and watch for the check engine light to blink. If it doesn't blink, the TPS isn't adjusted properly (stupid sensitive bastards). I have no experience w/ mkIII ts so excuse me if I sound a little ignorant, just trying to help
Jimi87T
1,126
4
Colorado Springs
Did you adjust it? BTW, I started mine once with out the TPS plugged in. It ran, just idled high. So if it's not starting/running, I think you have more problems than just the TPS.
jjones86
14
orlando
when i first got it (a couple of weeks ago) it started up and like u said it idle high. but if i gave it some gas it shut off. now it won't even crank up
Tanya
1,851
Naples, FL
it won't crank as in the engine doesn't even turn or won't crank as in will turn but won't start?
jjones86
14
orlando
sorry
it will turn over but not run
i'm was just trying to find a place to start looking. this is my first supra and i don't know that much about them
Tanya
1,851
Naples, FL
ok, when she cranks is it a really fast kind of cranking or a slowish normal crank? If it's a fast crank, could be a nice sign of a loose, stretched, broken timing belt.
Find out the basics first.
Spark, is she getting it?
If yes, is she getting fuel?
jjones86
14
orlando
now that i think about it, the guy i bought it from said the car had been sitting for awhile. so the gas could be bad.
