First off, this is my first post. just signed up last night! mostly just so i could ask this question..
So, to start, i'm looking at buying an 86.5 with a 7mgte engine swap, asking price is $1700. not too bad!
However! there's a catch. the guy hasn't figured out why, and i've searched all over google and other car forums trying to find an answer but i have come up with nothing! just a bunch of possibilities! so, i'm wondering if anyones had the same issue!
the issue is, the engine makes a pinging noise, but only between 1800 and 2200 rpms, nothing below or above! he got the engine from a different supra, and when it was in the other car, it made no noises whatsoever, but as soon as it was put in the 86.5, it started making that sound. He thinks it may be a timing issue because the timing does need to be properly set.
the possibilities i've found are:
spun bearing
timing
harmonic balancer
valve stem oil seals
carbon deposites
spark plug chamber
lifters
knock sensor
heat shield
catalytic converter
i've ruled out the catalytic converter mostly because when i went to go look at it, it didn't smell, and the sound seemed to be more the engine than exhaust.
he also took me for a drive in it, and it rides really smooth. that's why he doesn't think its a spun bearing because he brought it up to fourth gear and it was running very smooth.
the noise also seems to only show up when the engine has warmed up a little.
anyway.. any idea's?
spun bearing
timing
harmonic balancer
carbon deposites
spark plug chamber
lifters
knock sensor
heat shield
catalytic converter
