new to supras one quick question?
BoostFreak
74
Ohio
ok here is the stupidist thing I have ever asked but, the car I bought has the t4 aftermarked manifold installed and had the oil dipstick removed and I can't find where it goes so any help would be great thanks.
PIONEER
Wallet Wide Open
Raleigh, Nc
if the dipstick shaft itself was removed then the only thing left is a hole in the block. its gonna be hard to point it out on your setup unless you show a picture. but its under the exhaust manifold about 5/8s of the way down from the front. Thats a little more then Dead center towards the back side of the block.
And Welcome to the board
PIONEER
Wallet Wide Open
Raleigh, Nc
IJ:- Is that an overseas version of a 7M-GE? where is the oil drain for the turbo? also the tube sticking out of the bottom is a detatched version of oil cooler lines?
Pioneer: Yep that's the Aussie GE they all have an Oil Cooler here!
The Turbo Oil Drain is left undrilled but in the past I've drilled mine as it's well above the Oil in the pan unlike the cooler return in the pan.
My new motor is my first GTE block as I needed the squirters this time.
