New Setup New dyno numbers
ians13
537
Jacksonville, fl
after redoing the exterior on my car I did a little power upgrades as well, big front mount ,hard pipes 2.5 hot side 3” cold side,driftmotion 57trim,ddp down pipe,560 denso injectors.
My boost controller took a crap and would not go past 14psi so all I could do was pull a little fuel
Before my upgrades, it made 300.8hp 321tq on a dyno dynamics dynamometer
After upgrades with the fuel at 10 it made 325hp 296tq on a dynojet
Here is a picture of my first and last runs, my best run was 339hp 308tq
ians13
537
Jacksonville, fl
yea a few, get my boost controller working :), I still need coilover’s, and just get all the kinks worked out like my very noisy rear end fixed or replaced and upgrade my bushings and brakes.
ians13
537
Jacksonville, fl
queenskid926;1579730 said:
you said the afr was at 10? still some more power to be made if you lean it out some more into the 11.x range
it was tuned to 11.5 but due to boost controller problems, i was limited to 14psi with a best run of 339hp 305tq,
---------- Post added at 08:21 PM ---------- Previous post was at 08:21 PM ----------
ask92;1579856 said:
^^^ x2....Car looks good!!
thank you.
ians13
537
Jacksonville, fl
charman02;1579855 said:
What's the mods? I know you kinda mentioned it, but a little more detail maybe? Internals? Intake? Exhaust? etc,...
Ok full mod list
Jdm 7mgte with titan 1.4mm head gasket "no egr" is the only thing I think that's different
560cc denso injectors
Walbro 255 pump
Aeromotive FPR with driftmotion kit.
Large front mount intercooler CX racing with 3" cold pipes and 2.5" hot pipes.
CX racing 16 row oil cooler
Blitz intake kit
EBay DDP downpipe, don’t buy down pipes from eBay this one needed major refab to work. 3” for turbo 2” for wastegate
Driftmotion 57trim upgrade turbo
Greddy type R blow off valve
Greddy profect B boost controller
Full 3” exhaust with no cats one 26” resonator
Drilled out fuel pulse dampener
Lexus AFM
SAFC 2
Fidanza Flywheel
Driftmotion stage 2 clutch kit.
ians13
537
Jacksonville, fl
queenskid926;1591438 said:
do you have any boost creep issues with the upgraded turbo and the ddp?
no none at all, my busted boost controller keeps me right at 14psi it's currently turned off and peak boost on the waste gate seems to be 12psi.
