new proptype dp that i made
bigaaron
4,692
Pomona, CA
www.driftmotion.com
shaeff said:
^ agreed. when i had my boost set to 15psi on my EBC (built into the MAFTpro), it wouldn't creep at all. rock solid boost, no problems.
when i had it set lower (about 8psi, it would creep to 10) ever since i increased the boost to past 10psi, i've had no creep issues at all.
but it's always nice to see more people innovating.
-shaeff
It is cool to see new designs and people coming up with fresh ideas, and I am interested to see Nashman's dp.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
peteyturbo said:
Sorry but that is false, please explain how that could be true..
I didn't feel like posting earlier, but:
I don't know if it's scientific, but it definitely feels that way.
From stock dp to aftermarket 3", you feel a slower response at WOT... however is quickly compensated on top end.
peteyturbo
59
Philadelphia
Sorry to break it to you but that REALLY is not true..Less backpressure will only HELP you turbo spool quicker..And as far as response off boost, less backpressure will will help marginally, you will not benefit from ANY backpressure on a turbocharged engine, the turbo itself provides more then enough as it is..
aznwaterboy
Swap never finished
Feb 5, 2006
139
Bay Area, California
Instead of creating a new 3" dp, can't you just use a normal 3" dp and weld a plate that divorces the wastegate from the turbo? IMO that would be easier to do but can it be done? That way people can use their own 3" dp's and just weld a plate to the dp.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
I believe the WG "block" on the stock elbow had something to do with it.
8,900
ma71supraturbo said:
Nashman is claiming that the divorced dp's creep because the wastegate's exhaust does not have vacuum.
He says that the non-divorced "megamouth" downpipes lose some low end power compared to the divorced.
His solution is to weld a divider plate in a "megamouth" style downpipe in hopes of having the best of both worlds.
Nash: How will this be any better than a partially divorced dp?
viewimagetext.asp
Damn, I need a nashman translator.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I'd like to point out to you all that if you check a BOSS turbo from suprasport.com they use the same idea in their turbos that NM is using. A bar is cast into the exhaust housing to separate the exhaust gases to reduce turbulence. It's really a good design and I've seen it on other setups before. I would just make sure that the splitter NM uses doesn't interfere with any splitter that is already on any aftermarket bolt on turbo that you all may be using if you're considering doing this. ;)
Mrbaboon
277
Victoria, BC
I whipped up version 1.0 awhile back. ma71supraturbo has the newly updated 2.0, with super mega dyslexia-infused-typing decoder action, but even with that updated niceness of a translator it still comes out fucked.
I went for a ride in Ryan's car on Saturday. Oh boy its got some pull to it after he got rid of that HKS piece of shit, although I do like my Nashman custom divorced down pipe more (yes he made that one too), and I only creep from 8 to 10/11 psi.
becauseican
Vancouver
www.bicperformance.com
Well there is some false statements on this thread about DDP's, and dp's but it has already been pointed out by others. A very small percentage of DDP users have boost creep, I would say maybe about 5%. I am still trying to nail down the reason why most people dont experience this while some do. There is just to many variables with different vehicles with exhaust systems, intercooler upgrades ( or downgrades) intercooler piping, condition of the engine, turbo, wastegate actuator, and the severity of cracks in the turbine housing.
But good luck :) the mk3 downpipe market is already quite competitive and watch out, the chinaman can and will copy anything!!
Randy
aznwaterboy
Swap never finished
Feb 5, 2006
139
Not to bash on your product, but wouldn't a rerouted ddp do the same thing that you're doing Nashman? Because rerouting the ddp would create a vacuum for the air from the wastegate, theoretically, unless I'm mistaking something.
Offtopic - Awesome job on your short-shifter, I'll probably be picking one up once I get a 7mgte into my car.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
oh i do nto intended to sell this in any way just shareing an idea for people to try
oh and the vacume whould be strounger if the pipeing is shorter
and if you dont like it just chop it off and then it si mega mouth again
just an idea fro you guys to try out
