New performance camshaft source?
X-man
member
Dec 5, 2005
309
Pulaski,Va
I was reading inthe new Turbo magazine and came across a new product add for camshafts.
Here is the page off the website from www.briancrower.com
Pricing seemed to be about 543.00 for 2 if I read this right.
The 7M-GE and 7M-GTE were both high-performance engines used by Toyota in the 1980's and early 1990's. Only two Toyotas ever featured the engines: the Toyota Cressida and Toyota Supra. Both engines were very advanced for their time. The 7M-GE came standard with the Cressida from 1989-1992, offering loads of power, excellent fuel economy, and proven reliability. The 7M-GTE was simply a turbo version of the 7M-GE offered only in the Supra Mk III and is the more popular engine of choice for tuners. The engines had a 3.0L 24-Valve DOHC Twin Cam setup which provided plenty of power for both the Cressida and Supra. The 7M-GTE is an Inline 6, or "straight 6" engine. The 7M-GE and 7M-GTE were both discontinued sometime after 1992 with the demise of the Cressida in North America.
Stage Description Cam # Adv. Dur. Dur @ .050 Lift (in) Lift (mm) Kit #
Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK. BC0321 264°/264° 220°/226° .336"/.332" 8.53/8.43 BC0320
Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires kit BC0320. BC0322 272°/272° 224°/230° .375"/.375" 9.52/9.52 BC0320
USDM 7MGTE (’87-’92 MKIII) Stock 256°/256° 201°/201° .297"/.297" 7.54/7.54
Bucket Diameter: 0.980"
VALVE SPRING/RETAINER KIT
Designed for high rpm, BC valve springs are wound from only the highest grade, super clean, chrome silicone alloy and feature proprietary processing procedures for consistent pressures. BC retainers and spring seats are CNC machined from 6AL4V titanium to exacting tolerances.
Kit # Spring # Retainer # Description
BC0320 BC1320 BC2320 Single spring, titanium retainer
Spring Pressure:
BC1320 Seat: 1.325" @ 90 lbs / Open: 0.950" @ 200 lbs / Coil Bind: 0.815" (no machine work required)
PRO SERIES 4340 STEEL BILLET RODS
Built from rugged 4340 billet steel, BC Pro Series rods for the Toyota 7MGTE are designed for high horsepower (1200+) forced induction applications. Manufactured on state-of-the-art CNC machining centers. ARP 220,000 p.s.i. bolts and aluminum bronze bushings.
Rod # C-To-C BE Bore BE Width PE Bore PE Width
BC6329 5.980" 2.166" 0.977" 0.866" 1.010"
STAINLESS STEEL VALVES
BC valves are made from premium stainless steel, fully machined and swirl polished for ultimate air flow. Dished head for added weight savings and increased valve control at high rpm. Oversize head diameter only.
Part # Description #
BC3320 32.5mm Intake (+.5mm head diameter)
BC3321 28.5mm Exhaust (+.5mm head diameter)
ALUMINUM PISTONS
Made from premium 2618 aluminum forgings that are application specific, CP pistons feature CNC craftmanship, made to only the highest tolerances. Each set includes pistons, 9310 nickel carbon alloy wrist pins, full ring pack and wire locks.
Piston # Bore Size Oversize Compression Pin Code Description
CP7470 84mm +1mm 8.4:1 0.866" Turbo
619.825.8719 (ph.)
619.825.9675 (fax)
info@briancrower.com Copyright © Brian Crower Inc. All rights reserved.
Sean
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Thanks Sean, I always see their ads in magazines but never looked into it.... good to know that there are more choices coming up all the time.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I like how you can get your engine internals from one source, and know all the parts were made with exactly the same care and precision. If I didn't have my engine assembled and paid for I would buy one of each of this stuff :biglaugh: . Future I suppose.
eric
X-man
member
Dec 5, 2005
309
Pulaski,Va
Just got off the phone with them and they got backed up alittle and are two to three months out, but they are new cores with the stock base circle and will be 500.00 a pair. Stage 2 is plug and play and stage 3 requires springs.
Sean
mkIIIman089
Ohio
Awesome, nice find X-man! And since I've never seen you on here before, welcome to the forums!
X-man
member
Dec 5, 2005
309
Pulaski,Va
I appreciate it. Brian told me to email him which I did and he emailed me back and said as soon as they are ready to ship he'd let me know. They are new cores not regrinds and the stage 2's are plug and play, but the stage 3 require upgraded springs. From all the cam manufacturers I've talked too they say you should not need shim under bucket kits unless you get closer to 10mm lift. I would guess 9.52 mm might be push the comfort limit alittle, although 2jz's run 9.35 mm with no issues at higher rpm so who know's for sure.
Sean
