new guy working on a 1uz 84 supra
the ghoul
86
warren, MI
Hey all,
Name is Kevin
for the last few months ive been working on a full gut and rebuild 84 supra project. It wasn’t till a few weeks ago that i decided to scrap my idea of boosting the stock 5mge and just doing an engine swap from the get go. Im a fan of old school muscle so the quad cam v8 1uzfe seemed like the way to go.
if you guys want to see specifics on my build ive got plenty of info on a local michigan forum
http://www.xceedspeed.com/forums/showthread.php?t=147183
basically the intent of this build is to take an old tired 84 supra, take it down to bare shell, get rid of all the things i deem unnecessary (cruse, AC, seat belt warning system ect) and rebuild it as smooth and clean as possible with all the modern toys i love for daily driver use.
so here is a quick blow by blow; (will be posted in build section soon enough.
10-4-09
84 supra 240k miles running (just barely) is bought for $750 and trailer home from Ohio.
I am amazed at how relatively rust free the car is
10-20-09
car is stripped to bare shell and the garage is stocked with new and used replacement parts
10-24-09
Engine compartment is stitch welded, and all unnecessary holes are patched (going for an aggressive wire tuck and battery/fuse box relocation)
door jambs, and rear hatch are also stitch welded
10-26-09
Engine compartment, door jambs, sun roof, fuel door, underside of hood, back sides of doors and hatch and in general all the 'hard to reach' areas are prepped, primed and painted. This was done so early in the game so that i could assemble the car over winter and then get it re-painted come spring and not have red door jambs and such!
11-2-09
Paid way too much for a non-ac heater box from an 82 celica, rebuilt it with new foam, repainted the fire-wall, and all the under dash brackets with por-15 (semi gloss black and silver respectively) and installed it all.
11-8-09
Installed a freshly rebuilt front suspension with KYB gr2 struts, super-pro poly bushings, vented black zinc rotors, and Dobson drop springs. I didn’t bother messing with the sway bar setup because that will be upgraded down the road. Also looked into it and made the decision to sell off all my 5mge stuff and pick up a 1uzfe.
(again, i used por-15 where ever i could)
11-11-09
Got a good jump on rust replacement/battery box fabrication
the ghoul
86
warren, MI
continued:
11-14-09
taking it easy i re-freshed the dash cluster and heater controls with blue LED bulbs and a general good scrubbing... Also seeing how the title already had an odometer discrepancy i figured there was no harm in marking the cars re-birth by rolling it back to 0
my boston Gizmo was less than impressed by the improvement!
11-20-09
using the plans from
http://www.v-eight.com/tech_forum/viewtopic.php?f=40&t=753
I fabricated two sets of trans adapters (1uz to w58) one of which is up for grabs :naughty:
11-22-09
More stitch welding and rust patching
(rear shock /wheel well)
(front frame/transmission area)
naturally more por-15
11-23-09
With a little bit of modification the 1uz auto bell housing test-fit looks to be very promising
currently
Work on rear suspension has begun, including the fabrication of solid aluminum sub frame mounts
and the 1uz is supposed to arrive today!!
And just think, that’s an abbreviated version of whats been happening!!!
Supbscribed.
Great job so far. What color have you painted the body parts? It looks blue, but it's kinda hard to tell. Keep the pictures and progress coming, and don't bother taking any time off for Christmas. It's way over rated.........:biglaugh:
Gizmo is the first Boston Terrier I've ever seen that color. My brother had the normal looking black and white one, and of course his name was Oreo.
the ghoul
86
warren, MI
suprahero;1458293 said:
Supbscribed.
Its a stock toyota color 'dark blue metallic' I forget the paint code off the top of my head... This picture has been tacked to my cubical since i saw it... this car is what i want mine to look like when its all done.
oddly enough, same color... its odd, its like a dark grey metallic but in the right direct light you can see the blue...
as for gizmo
he is his mothers 'special little boy'
He is a pure boston (paid enough for the papers to prove it) most we can figgure out is he is a variation of the seal coat type. According to standards the seal is a very dark brown...
gives him a little spunk i think!
I had a black '83 model for about six years. I loved that car. It's now resting peacefully in a field less than a quarter mile from my house.
the ghoul
86
warren, MI
wow,
thank you all
yeah i might just have to open this up to a full on project log now that so many people like what they see already....
4U2QUIK
1UZFE SWAP DUDE!!!
good going! It looks like your swap will be exactly the same as my friends 1uz cressida here in town. I'm hoping the 1uz you gotcame out of a ls400 or atleast a front sump engine.
btw if you have questions about the swap feel free to ask, and I'll relay them to my friend with the cressida.
the ghoul
86
warren, MI
yep, you got it
obd1 ls400
front sump
