hey guys ive been searching around and i still cant find the answers im looking for.
i replaced a hg on my 7m with an hks 1.2mm with arps and all that.
it leaked. i had everything prepped properly and torqued right.
im going with a felpro oem replacement gasket and arp studs.
can you guys please help me out with the following questions.
1. does the gasket need a sealer (last time i used copper spray and all it did was clog the cooling ports on the head, also ive heard the flepro gaskets do not need a sealer)
2. with the arp studs and a OEM gasket, what should they be torqued to ( the stud and the nut itself)
3. do the studs NEED moly lube? and why?
4. is there anything else i should be aware of while im doing this?
thank you all in advance for your help.
-luke
-luke
