Need some help.
harmless
11
untied states
Just picked up a 87 built 7mgte. 3bar with translator, big front mount, t4 turbo, 750cc injectors, forged internals, new fpr, 1jz intake, walbro 255, safc ii.
Car runs perfect out of boost, feels normal and revs all the way to red line. As i get into boost, i start to feel power but as i get closer and closer to 10psi, it feels like something just holds me back. I get code 22, 51, and 52. AFR is at 13 at idle and 11 while in at any throttle, never goes lean.
Do i just need to go and rewire the knock sensors with shielded cable?
Also my safc ii reads a knock of 70-80 while idle once its warm?
Header glows red.?.?.?
Id love all the help i can get.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
Rewire the knock sensors.
My theory is( and i WILL be corrected if wrong), The ecu is running the car either rich, or retarded timing(or both) due to the code 52.
That's why you have rich AF's in part-throttle, and might explain why you're getting an incandescent nightlight manifold(the fuel is still burning as it exits the cylinders).
harmless
11
untied states
car is still falling on its face, the knock ready is now at 70 once warmed up but shoots to 120-200 when on boost so i know its reading, fuel is at a constant 12-13 while in on the throttle with fuel regulator set at 44psi. still left with code 22 and code 51 every time, so 52 is now gone. ugh, this poor motor lol. a/c is off when getting codes.
afr is 14 at idle but changes and doesnt stay steady. idle is .8 volts at zero throttle and 3.9 at wot so i think something is wrong here
could there be a chance my cps is WAAAAYYYY off?
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Code 22 should be easy to fix. Just do it. (Open or short in water temp signal.) Probably disconnected at the sensor. I believe that this can be replaced with a single female spade connector if the wiring connector is broken.
Code 51 is probably a TPS calibration error. Just fix it.
Car should be set to 10* btdc ignition timing.
Also bad cat could cause the glow.
Are you running maft pro and safc?
harmless
11
untied states
nope, just falls. and if im at 10psi say at 3500rpm and release the boost pressure and get back in without boost its fine. Only only boost is when is falls off.
DeMoN2318
572
Arizona
my initial thought was not enough fuel but you said you AFR is ok in boost. So now I am thinking ignition...
check your timing again maybe?
