Need some help with programming Peak Prosport Gauges
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
What's going on guys? Shaeff (Chris) and I finally finished installing my new 5 Prosport gauges. Everything looks phenominal. Well worth the money so far. I'll get some pics up soon. I just wanted to know how to program these damn things. I tried to figure it out by the directions, but no luck. They just keep beeping and flashing from Green to Red. Any body know what I need to do? Thank you in advance!
Mo
cactus_mole
178
Santa Rosa, California
Make sure the plugs on the back are pluged in ALL the way. Mine were not and they would go all crazy. After they were pluged in they worked great and they also look good...:icon_surp
Mo87NA
8
Upstate NY
Here's a few.
Mo87NA
8
Upstate NY
Couple more.....
Mo87NA
8
Upstate NY
Last two...
Mo87NA
8
Upstate NY
Unfortunately the gauges arent working now. I'm not getting any readings from the sensors and two of the gauges keep blinking and beeping. Something isn't right, but I have no idea what....
Mo87NA
8
Upstate NY
Yeah I did. They were very helpful. Im gonna try finding a different power source. I used one that was already ran by the previous owner, however, it's possible it isn't a full 12V sourse and that's why I'm not getting any sensor readings. We'll see how it goes....... =(
Mo
dbsupra90
toonar
indiucky
looks good mojo. ive noticed on some electronic stepper motor controlled gauges the needles kinda flick around, not a smooth motion. have you noticed this at all?
as far as the problem, i would def check both power and ground sources. if either are weak, it will cause problems. some elec devices are very voltage sensitive. i would lean towards this being the issue since more than one gauge is giving you the same problem.
good luck!
buy a wheelskins for your steering wheel, I have one on mine (it's obviously pretty old, was on it when I bought it) and I love it...
Mo87NA
8
Upstate NY
Hahah dont worry. The steering wheel is coming. I actually saw a guy who put a '02 Celics GTS Steering wheeel on his supe and it looked great. As far as the color, the best part is, they can be either white or green. Shaeff and I wired them so depending on how I feel that day, I can switch the color at the flip of a swith. It's kinda cool.
Mo
