need serpenten belt for 1jz /w ati crank pulley
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
for the guys that are running the ati/titanmotorsports crank pulley, if anyone has the partnumber for the belt to use with the smaller pulley, titan only has the part number for a/c, i do not have a/c on my 1jz. I know there is a sticky for one without a/c on the factory crank pulley, if anyone have this information would be very helpful, i just don't want to play the game try and find the right belt, because that will probably kill a whole day going back and forth to the napa store thanks!
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
the way i did it on my 7M (way back when), take a roll of twine, run it in the routing for the belt, cut it to where it meets the start, measure that, then subtract about an inch from it to account for the tensioner tightening up
tsuper92
supra addict
Apr 7, 2005
1,376
mass
my ati damper is bigger then the stock one in diameter,not sure what you have.i'm not running a/c either,but i'm using the stock size belt.
