Need insight on what kind of electronics to buy to monitor 1JZ!
808steeze
28
Hawaii
I have almost rapped up my bid and I wanted to know what products people are running to control their 1J.
I just have ported wastegates, custom y-pipe and downpipe, cat delete exhaust 3", driftmotion intercooler kit for stock twins 2.5 piping.
I was thinking of buying an EBC, Boost Gauge, and what will I need to monitor afrs.
Is there something I can buy that incorporates all of these.(looking to run manual boost gauge not electric.
Your preference and insight much appreciated!
Thanks.
te72
Classifieds Moderator
6,616
9
WHYoming
Thanks.
Uhhh... come again? Wait a minute... do you mean a mechanical boost gauge?
You might look into an AEM serial gauge, but you'll need an AEM ecu to use it.
kelson
270
Socorro, NM
this innovate LC-1 and ssi-4
http://www.amazon.com/Innovate-Moto...&sr=8-3-fkmr1&keywords=innovate+wideband+ssi4
which is stupid cheap and works well. the ssi-4 lets you monitor 4 channels and you can datalog with the software. so I have it monitoring AFR, Throttle and RPM. then you can even do 3D graphs of it too.
I have that paired with an apexi SAFC-II. so about 400 bucks to be able to play with your AFR a bit. best deal if you're on a budget, i
IBoughtASupra
4,455
Queens, NY
Wideband, oil pressure, oil temp, engine temp and boost. Those are what I would get.
You could get an AEM ECU and then get the serial gauge to display all what you need.
