need help with turbo upgrade????
AS_supra
cali
its time for me to make more hp and im stuck on 2 turbo that i want.....the hks t51r and the gt-47....which one of these makes more hp and can be very useful on the 1jz...planning on running singles......looking at at least 650 plus hp....is it a good idea or no...i need help on this...thanks
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Those turbos are FUCKING HUGE, and overkill for 650whp on anything but pump gas. That looks to be a horrible idea, look for something smaller like a 67mm, It will get you to your goal.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
yea those turbos are too big, you should only use those if you are planning for around 1000hp. try something like the garrett gt4094r, gt4088r, pt66, or pt67
AS_supra
cali
well...i like how the t51r spool but i heard they lag a lot and the gt47 are like great but dont have that much nice of a antisurge housing...but looking at 1000hp is great but its too high for me...im looking at like at least a 11 sec car...that should do my trick.....any advice for me...how bout...whats gonna happen if i put in a t51r onto my 1jz...could anything possibly happen bad??
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
you like how the t51r spools, but heard they are laggy? so you like a laggy turbo? if so go ahead and use it. but yes those turbos are gonna be laggy thats probably the only bad thing thats gonna happen. oh the other bad things thats gonna happen if buy that t51r is your gonna be broke man.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
if you want about 650hp and run 11's i would suggest something more like an sp63 or sp67. sp63 will get you into the 11's with nice spool, and good response for a nice daily driver. also gonna save your bank account.
AS_supra
cali
wow.....wait...how bout the wotm turbos....will they fit the 1jz......but i like the way u describe ur gt40...mite just grab that then!!!!
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
For the turbo, I would look at Precision Turbo.
they offer the GT40-88 with a .81 T4 housing, and the GT40-88R in a .86 T4.
I ran the 40-88 on my 1JZ, it hit full spool about 4500. It was a little laggy for my tastes, but came on like a freight train.
Cya
628
Columbia, S.C>
if my number are right, 650 with our power to weight is 10sec. territory, depending on the driver and other variables.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
I will sell you a turbo setup that will get you to the 11s, make ~550whp (as done on a 7m with the same turbo). Should see full boost close to 3500 and possibly less with a standalone. PM me if you want more info.
