Need Help with Networking
empera
Authorized Vendor
Philly.
hehe well its been a while and my memory is bad, i hafta trouble shoot this though...
ok so im trying to set up my networking with the following set up...
Laptop with wireless card address is 192.168.1.101
PC #1 with NIC card 192.168.1.100
PC #2 with NIC card 192.168.1.102
all going into wiresless/ethernet router thats going into my cable modem. 192.168.1.1
I can access and ping between the laptop and PC #2 but i cant access nor ping this PC #1 ( all have access to internet ), i cant even ping myself. i checked the settings and all seem right but there might be something im missing?
if you can help please let me know, i'd be easier on AIM or something.
lagged
1991 1JZ
new rochelle
1. what type of router are you using
2. are you using DHCP
linksys routers by default use 192.168.1.100-(whatever the limit is) for DHCP clients.
if your DHCP IP pool is in that range and you manually set a host to use that IP youll have conflict.
use ifconfig to check each hosts actual IP address.
EDIT: replace ifconfig with ipconfig if youre using windows. (sorry, stuck in the UNIX world)
empera
Authorized Vendor
Philly.
i havent touched the DHCP settings and im using the Linksys router, WRT54G, i did ipconfig on all computers and those ips i listed are the actual ips...i cant ping this computer at all though.
lagged
1991 1JZ
new rochelle
basically, if all the computer use DHCP and can all get out to the internet then there are only a few things that could be the cause of this. you said they can all get out, are you sure? double check by pinging the default gateway.
a. you are doing something wrong (such as mistyping the IP address)
b. pinging is disabled
what are you actually trying to do?
empera
Authorized Vendor
Philly.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Julio>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
empera
Authorized Vendor
Philly.
C:\Documents and Settings\Julio>ping 192.168.1.100
Pinging 192.168.1.100 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.100:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
What im trying to do is...be able to share files/printer with all computers, this is the main computer and i cant access it through others or cant ping itself.
empera
Authorized Vendor
Philly.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Yes i can. this is wierd..never had a problem like this.
lagged
1991 1JZ
new rochelle
Request timed out.
Request timed out.
Request timed out.
Request timed out.
post the output of:
ping 192.168.1.1
ping 127.0.0.1
if you cant pint 192.168.1.1 id be very inclined to say that youre not plugged in.
empera
Authorized Vendor
Philly.
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Documents and Settings\Julio>ping 127.0.0.1
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
empera
Authorized Vendor
Philly.
Laptop
Pinging 192.168.1.101 with 32 bytes of data:
Reply from 192.168.1.101: bytes=32 time=19ms TTL=128
Reply from 192.168.1.101: bytes=32 time=1ms TTL=128
Reply from 192.168.1.101: bytes=32 time=23ms TTL=128
Ping statistics for 192.168.1.101:
Minimum = 1ms, Maximum = 23ms, Average = 11ms
empera
Authorized Vendor
Philly.
PC#1 (this computer)
Request timed out.
Request timed out.
Request timed out.
Request timed out.
empera
Authorized Vendor
Philly.
PC #2 is off...
C:\Documents and Settings\Julio>arp -a
Interface: 192.168.1.100 --- 0x2
Internet Address Physical Address Type
192.168.1.1 00-0f-66-51-4b-53 dynamic
192.168.1.101 00-11-50-1c-4a-9d dynamic
lagged
1991 1JZ
new rochelle
well that all seems right... ill have to think about this for a moment.
while im doing that reboot your computer and see what happens.
lagged
1991 1JZ
new rochelle
empera said:
tried that a few times...and havent changed anything since reboot.
use the windows utility and renew your ip address.
if that dosnt work, manually assign its IP address, netmask, default gateway, and DNS servers and then see what happens.
empera
Authorized Vendor
Philly.
3rd party firewall...norton anti-virus has a "internet worm protection" crap so i looked at the gen. rules and ICMP and a couple of other things were blocked.
Thanks a lot for the help, you actually refreshed my memory with a bunch of stuff...
