need help with leaking problem
supra-addiction
111
hampton
in the pictures; it's a "worm gear clamp" with a little bit of hose up under it..fluids leaks from out of it..can you all tell me what it is and where it goes.? thanks
Mk3runner
2,033
Nor Cal
looks like heater core line.. I think hard to see. that routes from the front of engine behind water pump to other side. so it "U's" around the engine.. its the main coolant pipe from water pump housing
looks like your a N/A, still should be the same setup. ima search for a pic from a trsm to show you.. maybe someone else will chime in before me
AJ'S 88NA
2,419
Florida
Yeah it's a cap. Get one from a dealer, the one's you get at AZ and other places don't have reinforcing in them and they don't hold up. I made a cap with 1/2" copper pipe/cap and a short piece of hose.
supra-addiction
111
hampton
oh okay..and when you say ( AZ ) what exactly do you mean.?
you made your own cap with 1/2" of copper. what kind of altercations did you have to make.?
