need help with hesitation
Supra87T
2-Tone BLUE
Feb 23, 2006
135
Cincinnati, OH
My 87 Supra has a hesitation problem between 2500 and 3000 rpm. It goes lean on the wideband (16-18 AFR's) and hesitates/bogs until about 3000 where all is normal again and AFR returns to around 11-10.5 under boost.
-AFM is good
-injectors have nice rhythmic clicking, verified by touching with screwdriver
-fuel pressure is 33 w/ vac 39-49 w/o vac
-plugs are new ngk's gapped to .028, new wires too
-coils are reading 0.00 ohms. tsrm spec says 0.3-0.5
Could coils not firing properly cause it to go lean? Anyone have similar problems or advice on other things to check. I'm running out of ideas.Thanks for any help....
8,900
How do you know the airflow meter is good?
Codes will only set when sensor is outside of its working parameters. A flat spot on TPS will also cause a hiccup or flat spot during acceleration. You need a scope to see it though.
Supra87T
2-Tone BLUE
Feb 23, 2006
135
Cincinnati, OH
I tested the AFM. I've also tried another one just to be sure. TPS voltage reads pretty steady and it's fairly new also. What kind of scope would I need?
Just for clarification, the car is not throwing any codes.
