Need help with fuel pressure issue
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Well here's the story
I have just fitted a gss341 walbro pump and now I have strange fuel pressure issues.
With the stock pump in place and running a constant 12v I adjusted my pressure to 36psi no vacuum and it ran solid and stable.
Now with the gss341 at 12v I have 46 psi with the engine running (no vacuum), but and here is the confusing part if I jump fp b+ its 34 psi
I just need someone else to sanity check whats going on, I thought jumping fp b+ gave you 12v to the pump so the fuel pressure should be the same ( or at least it was with the stock pump.)
7MGTEsup
Jun 14, 2005
614
England
dbsupra90 said:
without the car running, your voltage is lower to the pump.
did you bypass or drill out the J tube on the hardline return?
Yes I did the j tube mod, I put a DVM accross the fp b+ terminal and it comes back as 12v. I think it might be my pressure regulator not having enough adjustment to lower the pressure with the higher flowing pump.
