need help wiring my temp guage!
supraGhost
212
PA
jetjock;1069338 said:
There better be two if that thing is meant to go in a rad hose. If only one you need to ground the sensor body. Same when testing but that should have been intuitively obvious...
so run a ground wire off of the red housing?
i thought i would need something like that but no one said anythign about it when giving me directions for wiring this... lol.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
There are two different sensors, one for the regular series one for the premium series
Usually sensors with only 1 wire are grounded from it's surroundings, ie whatever is is installed to...
Is there only one terminal on the sensor?
If so I'm not sure how it would get a ground being spliced into a radiator hose with that adaptor...
*got beaten to it!*
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
I believe the red housing is anodized, and that means it's non-conductive iirc, you would need to run a ground wire from a conductive point on the body of the sensor
Or just do it right, get a bushing, and install it pre-thermostat
supraGhost
212
PA
yeah that worked. its dumb because there is no place to connect a ground wire to it but i will rig something up....
and i wish i had time to do it right but i dont. once i get me new car i will.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Thanks jetjock, the key is that I know what I don't know, so I don't speak it, more people should do that around here! :biglaugh:
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Ha, even if it wasn't anodized, it's not like it has a ground path when it's only connected to a radiator hose
Btw, the cost of a new coolant hose, will outweigh the cost of just getting the bushing and doing it right the first time ;)
supraGhost
212
PA
well its finally back on the road and it is slow as balls. i dont know what happened while it was sitting but it runs liek shit now.
