NEED HELP!! where do these parts go!?!?!?
doom26464
Research...research
Saskatoon SK, Canada
Ok I can't seem to remeber where these 2 parts go on my engine. I put pieces of tape on them with little hints to help me remeber but Still can't remeber.SOooo this is where I need your help supra community. Ok first off the left one says Vaccum line front of engine and the right one sayd oil line(oil line LOL that doesn't help much) anyone have any idea where they go plz?!?!?
spoolint78
Representing T.O
T.O
the one on the left is vacuum.
it wraps around the front of the motor.
it goes to the power steering pump.
the other one looks to be the oil cooler lines.
tte
Breaking In - in progress
Northern California
Like Spoolint78 said...
One end of Vacuum line goes to the power steering pump and the other end to the lines for the vsvs under the intake manifold. This line sits in front of the front timing belt cover.
As for the oil lines, the end with the banjo connector bolts onto the right side of the oil pan into a threaded hole and the other end hooks up to the metal lines in going to the stock oil cooler.
The other oil line also goes to the oil cooler and the other end goes to the oil filter.
Cheers,
Roy
