Need help!!! Walbro Pump and my shitty wiring! 2jzgte swap relies on this!!!!!
tissimo
Stock is boring :(
Melbourne, FL
What does the stock ecu do with the fuel pump trigger to the fuel pump ecu? does it give a constant 12v signal? does it give a ground? I havn't tested it, not do any of the manuals I've looked at say anything. Once we figure that out we can figure out how to get around it.
jdub
Feb 10, 2006
10,730
Valley of the Sun
I was wondering the same thing about the 2J ECU...either 12V or gnd could be used to trigger a relay.
Dr Tweak
Yeah I was trying to think of a pin on the ECU that gives either of those signals all the time and only when the engine is running, but I can't think of anything. All the ECU inputs and outputs work normally with the key on/engine off.
ECUs that use a Circuit Opening Relay give a ground signal on the FC circuit to turn the pump on.
jdub;1113153 said:
Might want to contact these guys...they have a US office:
http://www.gastec.ws/contactdetails.htm
About this:
http://www.gastec.ws/productSD40.html
Yeah I found them yesterday and sent them an email, I called but they said that they don't answer the phone and they prefer email, no response yet but I'm hopeful :)
-Doc
Dr Tweak
Okay I've been in contact with an electronics company I work with and I have good news. They can build us a module to turn the fuel pump on when a tach signal is being received just like we need. The module is $99. If anyone wants one, just let me know!
-Doc
SupraMario
I think it was the google
7
The Farm
That and it would be something extra to buy or find. As most engine clips just come with wireing harness and ECU.
turbogate
Life is Boost
May 18, 2005
425
South, FL
Am I correct in assuming that those with standalones don't have this worry since they can definitly activate a fuel pump at a certain rpm?
Thanks
