This one's pretty simple. I just bought a 50MM Ebay Wastegate (SSAC) and I'm about to finish up my 1JZ / Holset swap. The turbo has 3 ports on it. A big one and a small one on the top, and a big one on the side. The screw in elbow will fit either of the 2 large ones. I'm going to be running the wastegate directly off of the turbo in the begininng but eventually I'll be adding a boost solenoid and using my MAP-ECU2 to control the boost. My question is how should it be hooked up? Both at first (direct) and down the line (Boost Controller)? Any input would be great. I'm getting impatient since I had a succesful first start-up tonight. Hopefully I can have it on the road by next week. Here's a pic of the WG:
