need help quick think something is really wrong
brs86supra
395
suffolk,va.
i think i have a serious problem, my turbo and my turbo manifold is glowing red hot. its never done this before and i also have not downpipe on it, my exhaust stops at the elbow. what could be causing this problem? any help will be greatly apreciated.
brs86supra
395
suffolk,va.
so a boost leak will cause the exhaust side of my turbo and manifold to turn red hot. its boosting fine, and is also running fine, except for the fact i am getting crapy gas mileage
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Yes. A boost leak will throw fuel (mostly unburnt) into the ehxaust system. When the exhaust system becomes hot enough, it ignites the unburnt fuel.
You may think you are boosting "fine" but its not likely.
Also, check ignition timing and cam timing.
brs86supra
395
suffolk,va.
i just went outside to look at it and there is white stuff where the elbow connects to the turbo, cant check timing yet cause its kinda late and dont want to wake any of the neighbors. plus i have that heat soak problem. would it hurt it to still drive the car or would it cause problems to my turbo and motor.
brs86supra
395
suffolk,va.
earlier today my heater core hose broke off and coolant went all over my engine. just a thought this might help diagnose but not sure.
1988SupraDreams
509
San Jose, CA
O2 sensor is adding extra fuel to get rid of all the extra air that it's detecting since it's about oh.. say three inches from the outside air. Put you DP back on.
brs86supra
395
suffolk,va.
ok thanks a lot guys i will put my dp back on today and go from there. also i am getting a code for my o2 sensor could this be my problem with it adding in too much fuel
MDCmotorsports
Indy 500
Supraboy89 said:
make sure that the coolant lines going into the turbo are not colgged.
This won't make the turbo glow red.
A broken o2 sensor is doubtful to be the culprit of making the manifold run that hot.
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
I's it normal for you to get a little bit of red glow just before the elbow when boosting hard. not alot just a very slight amount?
brs86supra
395
suffolk,va.
ok just checked my timing it was way off and my afm is now gone. everytime my afm is plugged in the car will die and when i unplug it, it will idle right, could a faulty afm cause my problem
brs86supra
395
suffolk,va.
yeah thats what i thought mine does the exact opposite idles with it unplugged and dies and idles irractically wiht it plugged in.
brs86supra
395
suffolk,va.
i got another afm in the mail as we speak so i hope that this is part of my problem. somehow my timing was like 2 degrees below tdc dont ask me how this happend cause i dont know.
