need help please.......
nschultz0124
25
Villa Park, IL
Hey all,
I have kind of a strange request. I was wondering if anyone has a good pic of the intake side of the engine with all their connections connected in the car. I am in the last stages on putting my car back together and I have a couple of ground wires that I cant see where to bolt them. I also have a few boken lines on the turbo side that I am trying to find where they go. one of them is yellow with a green stripe and the other is yellow with a black stripe. any help is appreciated.
Thanks,
Nick
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
As far as grounds go, you should be able to ground any ground wire to a good solid grounding point. I don't think it really matters that the stock ground wires are grounded in the same place, but we'll have someone confirm this first ;). You may want to replace the stock ground wires with larger, new ground wires.
As far as the broken lines go I'd have to see a pic...
Ninja edit:: Grim's post helps out a lot ;).
nschultz0124
25
Villa Park, IL
GrimJack, I was wonderinmg if you have any pictures of the exhaust side of the motor as well? specifically the oil pressure sending unit or where the wire plugs in to it.
Thanks,
Nick
