need help on 7m swap
domdomleblanc
8
quebec
hi
my english is not very good but i'll try my best to explain my problem clearly as possible
I just finish my 7mge swap in my 4runner(from a cressida 90) and it was running fine for few days but last night a took the truck for a small ride (first time on the highway)
I was going 70km/h at 4000rpm and the engine start to miss very bad .......i was not able to drive it so I let it cool down .....the temp drop to 180 degree and I tryed to start it again ..everything look fine at idle speed but as soon as I drop the clutch on first gear it miss again and stall
I dont have the speed sensor plugged into the ECU
I don't have check engine light on but when I jump the terminals I have the code 14 ... so I check my ignition coil resistance
I have 10.68 ohm K between the positive terminal and the high-tension terminal.....that's perfect
and I have nothing between the positive and negative terminal... should have 0.24-0.30......
I have 6 function to mesure the ohm on my multimeter : 200 2k 20k 200k 2m 20m and any of them give me resistance
Do I have to buy an other coil ????
i have change the gaz filter rotor cap rotor wire and spark plug ....I carefuly gap my spark plug at 0.028
8,900
Did you actually overheat? Did the needle to go the top of the guage?
I don't think that will matter. But you need it.
14 means the ECU isn't seeing that the coil fired. That is definitely a problem.
Just to be sure, you have no resistance, or infinite? No resistance will show a 0 on the display, and it means the coil is short electrically. When you touch the leads on the meter together, does it say 0?
Sorry. I don't know what you mean. I know you are saying your meter can be scaled, but want to know if you are outside limits, shown usually as O_L, or short, shown as a 0, zero.
Did you follow this?
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=IG&P=5
That is too small. Bring it up to 1.1 mm. I assume you have a metric gauge? .043 if you don't.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=MA&P=7
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
Speed sensor. Where is that? I installed an eclipse touch screen with navigation. And it needs to be hooked up to the speed sensor.????
