need help no spark
big yoggz
ok i been searching on the treads for answers founds a couple of things. im doing a 1jz swap and i got fuel pressure going but no spark. i read somewhere that i have to have power on both wires of the coil packs and ionly have power on one cable. i also read that i have to check the crank sensor but witch one is that? a pic would help me a lot but other then that what can i do? also the igniter is new from dm.
JonoTurbo
Going for broke
CT
Check for codes, make sure you don't have code 14.
The crank sensor is located below the alternator going into the block behind the crank pulley. The plug for it is up by the water pump. I don't have any pics for you at the moment, sorry.
big yoggz
ok koo i think i know witch sensor u r talking about. to check the codes in with points do i put a paper clip?
