need help just got an 87 turbo dont know if turbo is bad
targa87turbo
31
fairfax county,va
hey im new to supras i just got an 87 supra think the turbo seals are bad it idles very bad it so slow and it smokes like crazy after the turbo stops spoolin but how do i know its the turbo not the head gasket also did a block test and checked the oil and every thing was good
plaaya69
87T Supra
Nov 18, 2006
948
10
Lake County, IL
How is the play in the turbo? any codes for the bad idle? have you done a compression test?
Edit: this is the section but you want the 7mGTE(turbo) not the 7mGE(non turbo) section.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
blue-ish smoke or white smoke? does it happen when you start the car off after it cools down? Does it smoke under load while boosting? Is the car overheating? how is the oil level? how is the coolant level? does it look like there is water in the oil? Does the turbo make any noise under boost? did you take off the accordian hose (hose from the turbo to air filter) and wiggle the turbo shaft to see if there is alot of play?
The more info you give the better we can answer your question. Use the search tool as much as possible and narrow your post down to the closest section possible (this would be best in the turbo section, 7mgte)
xarewhyayen
Oct 3, 2005
959
Philly
targa87turbo;1091558 said:
just got it a couple of hours ago
do some research about the car and use the search button before you come and look for a magic answer. We can help you if you help yourself first.
targa87turbo
31
fairfax county,va
i did do some research the oil seals in the turbo are bad to my knowledge but i dont know why it s idleing bad dont know much about supra ilove honda so im new to this mk3 thing not looking for some magic answer just some help
xarewhyayen
Oct 3, 2005
959
Philly
kk, check out the things i said above in my first post. Let us know how those come out. Probably should get the turbo rebuilt for starters or you're gonna run low on oil and spin a bearing. Then go from there. A leak down test wouldn't hurt either.
targa87turbo
31
fairfax county,va
thanks alot going to check out that post asap:icon_bigg
jetjock
creepy-ass cracka
9,439
I'm curious. Why would you buy an engine that exhibited such symptoms? Only reasons I can see are A) You failed to properly inspect the vehicle or B) You accepted the problems and intended to effect repairs. Am I missing something?
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
And this is in the GE section?
So how many people actually realize that the TSRM gives exact instructions on how to properly inspect the turbo? I know it's tempting to just wiggle and guess but take it off the engine and use a dial gauge.
