hey guys i need some help, there is something really wrong with my car. i know this isn't the 1jz section but i haven't had any luck there so i'm hoping this has happened to a 7m and maybe you guys could give me some insight. it runs super rich at idle and partial throttle, around 9:1 a/r but once i hit wot it gets super lean, 14+ a/r... it also chokes and bogs like crazy under 2000 rpms or 35 mph, it feels like its not going to be able to move anywhere because it chokes and bogs at 1500 rpms but once i get above about 2500 rpms it runs a little smoother but still bogs and chokes alittle. overall it runs really rough no matter at idle or when i'm driving and it sucks gas down like no other, i drive around town for like 10 minutes and i can see my gas gauage sink. i think it could be my 550s gone bad or maybe my walbro fuel pump, i thought it was my 1j ecu but i put in a patch/jumper harness with a 2jz ecu and an emanage ultimate and it still runs the same as when the 1j ecu is in. i've switched the ecus around numerous times and i'm stomped so i was hoping you guys could help me out. my mods are pt70 single, 255 walbro, 550cc usdm injectors with 7m resistor pack, and a 2jz ecu with an emanage ultimate. let me know what you guys think and if you have any questions just ask. I forgot to add that it happened before but it went back to normal after i turned off the car for like 5 minutes then turned it back on and there were no codes thrown. it also idles around 5-600 rpms with misfire. walbro has 12 volt mod and the car ran fine with the 550s before this problem. also i have a kill switch on my pump and when i turn it off the car still runs like the pump is still on but the car runs a little better with the kill switch turned off... and it happened when i was on the dyno, i never had problems when driving on rough roads or going over bumps...
thanks, toua
thanks, toua
