need help changing head gasket
hi my name is Basit and im 14 i have some tools not much got like metric tools and such and no air tools but............ i just bought a 88 supra 7mge for 575 knowing the engine wont crank at a auction but car was locked and didnt check anything else. thought it was just a starter because i put in a brand new battery about 2 days old from my 240sx and it got drained like super fast. no other problems until i checked the oil it had like wuite cream on it, blown hg. need to replace already ordered starter but hg should i get like one from ebayy for like 60 as a set or buy oem from toyota im planning to do a mgte swap in a few months but just wanna drive it a little before i do that. need some serious :1zhelp: thanks for helping and posting images tommorow of car.
s383mmber1
3,614
Somers New York
OK!
here we go!
First of all, what are your power goals? Im sure you want a moderate amount of power, if so look into a cometic head gasket, dont cheap out! Also i STRONGLY reccomend that you get new head hardware while replacing the HG. ARP's are awesome hardware!
Second, have you considered converting your car to turbo? Thats what im going through right now. Basically you get the turbo, manifold, electronics and associated parts and bolt them up to your engine. This is called NA-T. A NA-T supra will make a considerably more power than a 7mgte from the factory. This is because of the higher compression, better flowing intake manifold and better cams!
You own a Toyota Supra. Don't cheap out!
O and my names William, whats your name?
Ma70.Ent
1,871
NJ
He said it at the beginning of his post.:stickpoke :D
Oh yeah, you'll make more power cause of higher compression but you'll probably want to retard your timing if you're going to NA-T, or run premium gas, or both if you want to run decent levels of boost.
EDIT: Also, a lot of questions can be answered with search. Most newer forum members don't try to search and it gets older ones aggrivated when they see obvious questions that could have been searched for.
s383mmber1
3,614
Somers New York
You shoudl be runnign premium gas anways......
s383mmber1
3,614
Somers New York
driftking786 said:
also should i just buy a 7mgte cuz car has 184,000 miles.
Well, you can do ALOT with 4 grand! And purchasing a 7mgte doesn't garentee it has low miles either!
Look at the rabid chimp motor. They come FULLY built!
or just build your own motor!
Start searching!
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
driftking786 said:
only have $4k to spend
Spend it learning about your car.
Do not do anything until you understand exactly what your doing. Read, soak up, and just familiarize yourself with information about your Supra. That is what you should do first. Then, once you understand it all, start putting things together.
Take your time... you have many more years to enjoy your car.
Drew
supramacist
1,501
The Grassy Knole
DUDE, I don't think your getting it/ Take some social jesture or direction and do what you are hearing wich is seek it out. By any means neccessary. Run a search for everything. Everyone does what you have done here and will is grumpy anyhow. Supramania is a more technical site than say...., The supra forums of horse power freaks. You'll learn more here if you just sign in and read. I have been a member for a while, and don't have many posts because I stick to the na section. Turbo's are on a different playing field than we are. Just think out your questions a lot more before you ask any. Welcome.
