Need help ASAP, supra is down for the count?
empera
Authorized Vendor
Philly.
car doesnt want to start, cranks but nothin, tried pulling EFI (cause its been runnin really rich), and nothin, pulled the #1 spark plug and the galley was filled with oil, wat could it be? Has been giving me this sort of problem for the last couple of days and seems to have reach its no start point...
PLEASE HELP
Thanks,
emp.
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
are the Injectors firing like have you listened and have you checked spark with out know these its inpossible to even try to help other than guess
empera
Authorized Vendor
Philly.
ok somehow it started, seems there was no spark so i smacked the igniter a couple times and played with the plugs and it went...fuckin supra!
supra90turbo
shaeff is FTMFW!
MA, 01440
So... let's really find out what's wrong with it, cuz you know it ain't fixed... lol
I can picture on Monday reading "God Damn Supra stranded me on the Freeway... It just died! piece of shit blah blah blah"
empera
Authorized Vendor
Philly.
lol, yea im tryin to figure it out but like anyother random supra problem, its a tuffy
Satan
Tampa
Sounds to me like something basic... like the ground wire to the coilpacks, loose connection at the igniter, etc, etc.
I'd take some time to just make sure that what "looks" connected, is actually connected and making good contact. The CPS wires are the trickiest that way. I used to have to "push" the wires thru the connectors, to start my 87T. That finally stopped working, s I had to hardwire them together (tho I shoulda just made individual connectors at each of the 4 wires).
steve_mk3
middletown, NJ
At the least, you need to clean out the spark plug galley and install new valve cover gaskets. replace the POS screws that hold the valve covers on with some bolts. The bolts can be found at home depot/lowes etc.
That could have been the problem, causing the plugs to ground out and no spark.
Start there, you already identified a problem that will come back to bite you in the ass down the road.
Good luck.
Steve
johnathan1
Supra =
Aug 19, 2005
5,056
yes, definitely check the CPS connector and wiring
if oil is leaking, that definitely will cause problems, like cylinders not firing, because the oil screws up the wires, happened to my supra a while back
if this is the cause, then you will have to replace the valve cover gaskets, and the wireset, could replace plugs too...
it may also be a good idea to retorque your headbolts while your at it...
hope i helped...
