So, I'm about to give up on this supra because I've tried everything and it still cuts spark at 2500rpm.
Details- New TPS
New CPS
3 New Coil packs
New ECU
2 New Knock sensors
New HAC
New Harness
New spark plugs and wires
New AFM
New Turbo
New Head with 264 cams
New metal head gasket
Block has 10k since rebuild
Timing has been checked 20+ times
Vacuum lines have been checked about 10 times
All new fuses and relays
Two step was also removed and so was Safc 2
I Have a ton of money in new parts in this car and it still isn't running right and no one has an answer.
Problem- Car idles fine 18mmhg vac. car revs up to 2500rpm then starts cutting spark and it starts to get really rich and spit flames, after about 4000rpm the spark is fine and car runs normal. how do I fix the cut at 2500rpm?
Details- New TPS
New CPS
3 New Coil packs
New ECU
2 New Knock sensors
New HAC
New Harness
New AFM
New Turbo
