i had to take out a piece of my turbo where the stock blow off valve goes, and get a custom pipe. so that solved my problem. my only problem is wiring it, have you wired your yet ?? another problem i had was the oil pan, it didn't fit so i had to use the 2jzge oil pan and make a hole for the oil return line n custom fitting for it. did you run into any problems ??
