need good advice
turbo2
59
hawaii
ok im changing my motor its knocking on heavens door. can i use my 87 ported head on a 90ish bottom end? what block electronics will i have to change? im also going to reuse my 1mm hk$ mhg cause i dont want to use my 3mm trust mhg. any advice?
turbo2
59
hawaii
cool thanks mdc. i would do a rebuild but everything is so expencive here in hawaii shipping just kills me. im only aiming for 400 hp so i should be good. i just need a lex afm and some 550 and ill be well into the 400s. anybody have anwsers to the other ?s ? thanks in advance
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
There are no sensors or anything on the head, but there are on the block, so you would have to use a wiring harness from an 90-92. Why are you using a 1mm HG?
MA70Snowman
374
San Diego
I'm going to say.. NO..ur fine.. install the engine. the only hitch is the T-stat housing, but ur keeping the old one so ur fine. I have a 90 engine (WHOLE engine) in my 87.. with an87 ECU and 87 harness.. no hacks, nothing (unless by choice for something totally unrelated)
turbo2
59
hawaii
but i though u could not use the harness cause they are differant.if i could do that that is very good news to me! can i still use my 87 head for power reasons? what would happen if i used my 3mm trust mhg?
