Need a favor... (pic of the '89+ LED brake assembly/gasket)
Doward
4,245
Alachua, FL
I need a pic of the +'89 LED brake light assembly. Specifically in how it is secured in the wing.
A pic of the gasket, and whether it secures to the wing, or to the led assembly, would be nice as well!
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
easy as pie look under the wing there is cover that clips off i did this some time ago i think you can take it form there
Doward
4,245
Alachua, FL
LOL, I don't have one - I have a replica aftermarket wing. The LED strip was siliconed into place, and I'm thinking of trying to replicate the stock led strip's mounting in it, if I can get a better idea of how it mounts.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
ummmm i see it just held in wiht 2 or 4 screws under the cap if you don't have cap this may be hard since you will need a plug and the yellow box for the leads all in all if you don't have hole for the leds this will be real pain in the ass
i you need mroe help i cna snap some pic's for you
i all so ahve black 89 wing and a blue one here just colleting dust
Doward
4,245
Alachua, FL
Yeah, get me some up close pics of the LED assembly pulled from the spoiler, and the mounting/gasket setup, if you don't mind?
KeithH
Portland, OR
The LED bar is secured to the access panel with several screws - this is done while the panel and the bar are out of the car.
The access panel is secured to the car with a single screw accessed through the center pillar of the wing.
KeithH
Portland, OR
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=7601&P=1
This page shows the access panel and gasket - access panel shows as 76871B on that page.
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=8117&P=2
This page shows the LED bar
The LED bar bolts to the access panel shown in the first link. Then the gasket and the panel are secured to the rest of the wing with a single screw up the center post of the wing.
I had to replace my access panel when I first got the car as it was broken - like someone was trying to pry it off.
Finding the screw in the center post of the wing is a bit tricky as you can't see down there. You just have to feel your way around.
