NA&turbo head
supraman508
496
maryland
would i be able to put my pops turbo cylinderhead on my na block?and where his cam position sensor goes is my distributor compatable to work in the same place?
supraman508
496
maryland
sthmstr;1309865 said:
As far as I know yes. The cams will be different profile though.
would i have to buy a turbo timingbelt and asfar as the different cams i'm guessing i will have to advance the timing.my buddy has a turbo and told me that the turbo cylinderhead is longer then the na head.
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
The only difference is the exhaust cam. Ian do your work. Slap away
sthmstr
219
Colorado
Yep, yep and yep. Head casting same, lift slightly different on cam and the cam gears are the same. No need for differen timing stuff.
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
Thanks for the morning laugh.lol Should tell your buddy that you just found out that the n/a head has higher compression and he should buy yours for another 25hp.:biglaugh:
Pass the slap to whoever told you then
supraman508
496
maryland
i will slap the sh#@ out of him the next time i see him lol.i did notice the exhaust side valves are bigger.Thanks guys you all are AWESOME.I'M gonna give it to my mech and have him plane it and clean it all up for me and then i'm going to carlisle to the car show in P.A and show off my 7m since last year their was only 1 supra.A 1980 supra celica.Anybody going to the carlisle import car show?
grimreaper
2,180
Dallas
learning is the other half then ;)
cam profiles are in the tsrm, along with anything else on the motor and it will display any differences that are ge or gte specific on parts like you are asking about
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
If I have been informed correctly the N/A inlet cam has 10* more duration than the turbo inlet cam (210* v 200*)
