Na-t questions
mecevans
1,295
M-bay, cali
Im making a list of everything i need for 87' GE block to GTE electronics NA-T.
Is this everything? i know i am forgetting something.
Electronics---
ecu and harness
tachometer
igniter
afm
02 sensor
Coil Pack
HAC
Fuel Pressure Relay
Boost pressure sensor
injectors
Exhaust/ Intake----
turbo cams
turbo
exhaust and intake manifold
downpipe
throttle body
intercooler and piping
Stock "Blow off valve"
accordian
Oil---
feed and drain
dip stick
pan
Oil filter housing
Oil Cooler
Oil Cooler piping
Oil cooler and Intercooler brackets
Other---
PCV/ISC hard and soft line
Power Steering Reservoir and lines
Throttle linkage
various Hoses/Clamps
New----
Head gasket
Timing belt
ARP studs
thermostat
spark plugs
wires
clutch
spinyard
always lurking..
Nov 1, 2009
49
Ottawa
well the only thing i think you missed was the turbo oil feed and drain. also i believe you got some stuff on there you dont need, like the fuel pump relay. I dont think that changed between the two (turbo/na). also the power steering res, but i think thats more of a preference. I got lazy and didn't move mine. Didn't really find that it got in the way at all.
hope it turns out better than my na/t (rod knock).
mecevans
1,295
M-bay, cali
what happened to it? my motor is not the original. it was rebuilt.
spinyard
always lurking..
Nov 1, 2009
49
Ottawa
rod knock. pretty common for any 7m. this was brought on by a blocked pcv, which in turn blew out the pan gasket and any oil in the pan.
for the five or so hours i drove with that engine, it was fun as shit. I love high compression turbo motors.
twan
93
Toronto, Ontario, Canada
that list looks good so far, ive actually been looking into dropping a turbo in my na sometime this year and i came across this website http://www.4cefed.com/conversion.html i dont know if this guy has a good reputation. but he mentioned something that wasnt in ur list, it was that the turbo block has oil squirters and na doesnt. i dont know how you could add that though.
mecevans
1,295
M-bay, cali
thanks for the heads up
only thing you can do about that is getting a turbo block. some early turbo models came with ge blocks.
Ma70.Ent
1,871
NJ
That guy has a GREAT reputation. He's actually the person I quoted in the NA-T sticky thread on top of this forum.
twan
93
are you serious!? either that search button is busted or i cant see whats in front of me! this is the dfirst na - t thread i found.
and do you think it would be okay if the oil squirters were left out? what would happen
ValgeKotkas
2,224
Over the pond
Isn't the plug for it in the engine bay main harness? I at least didn't find a plug for it (I'm in the process of doing NA-T, about 85% done I think). Am I blind?
mecevans
1,295
M-bay, cali
does the turbo water neck differ from the na one?
is any of the egr system different from a ge? im in cali and they are smog nazi's!
what hp level is a stock w58 clutch good for?
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Dude.
Theres a online EPC.
USE IT.
ELECTRONICS PART CATALOG. Do you see members asking these questions?
YES; It's different.
More than the transmission.
