OK, i'm doing the 86.5 NA-T with GTE Electronics, and a maftpro with the MAP sensor. i'm going with 550cc RC injectors, CT-26/57Trim, will i be able to use the piggyback ecu to adjust for bigger injectors??(i know i can adjust afr) and i CAN'T adjust timging(thought i could) so will the GTE ecu make up for it? or should i retard it a bit to make up for the higher compression?
please any help/advice is munch wanted(and prolly needed) she's gonna go under the knife in 11 days, so i will prolly have more questions and i guess i'll start a build thread so people can learn from my mistakes:nono:
thanks again guys:icon_bigg
Since its a na-t, i think i'm in the middle for the right forum to post in.
