Na engine bay shots!
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
D TR41N
135
Milwaukee, WI
Suprarook;1015073 said:
Here's one of mine last year..I have no current picture, but now it has some mild mods and more DIRT...lol
Looks Good! Update with a new pic for god sakes! We have to see the dirt!
Suprarook
Ninety-Chew Mk-Tree
Mar 18, 2007
102
wisconsin/illinois border
Ok, heres today's supra bay picture and I included my 4runner's motor for shits and giggles....you can tell the two motors they are related...
todays supra-told ya iz dirty...in process of repaint and body work so engine is neglected now!
4runner engine
amichie
182
sYDNEy
Does anybody know why the supra Y pipe has a little cover plate just where the two branches of the Y meet? I have seen some with and some without that little cover.
AJ'S 88NA
2,419
Florida
JDM's do not have the "clean out" cover. I don't know why it's there other than access to clean it out some from the PVC deposits.
gofastgeorge
944
Texas
EGR passage.
The Japanese don't use an EGR, so they don't run the passage.
If you put the JDM Y-pipe on a car with the EGR,
the EGR becomes a engine bay decoration,
and no longer puts exhaust into the manifold.
But it's still there to keep emission inspectors happy :)
D TR41N
135
Milwaukee, WI
Looks like you got some oil on top of your spark plugs.... :-\
Suprarook
Ninety-Chew Mk-Tree
Mar 18, 2007
102
I have oil everywhere... What u are seeing in the photo is the valve cover bolts on driver's side were loose and was leaking (i know...not good), I didn't notice this problem until I parked it for the winter and I just have not cleaned up the motor since.
Too damn busy fixing the dents/scratches/etc and sanding for my repaint, motor will get nice overall once bodywork complete.
86yota
87
upper darby ,PA
ya i started the body work and after half way i had a rod knock and then after weeks it blew the #1 piston into the oil pan...haha But i started to smooth the body molding away with a bondo on the bottom and i still have to fiber glass over it a few layers i had a problem already with the front fender cracking a little
Suprarook
Ninety-Chew Mk-Tree
Mar 18, 2007
102
Looks like much more of a project than mine with the molding removal and fill in. I've heard mixed emotions on the trim removal, I think it looks nice that way, but must be a killer to get perfect, eh...
AFQC
What was that noise?
Mar 30, 2008
57
Vancouver WA
Nice and clean :icon_bigg
I put a fair amount of time under the hood last week. It developed a nasty misfire Tuesday and I was thinking “nice…another BHG” but it turned out to be just a wasted cap and rotor. But since I had the time I went ahead and changed out plugs to NGK iridiums, NGK wires, and new cap/rotor. While I had the plugs out, I did a compression check and came up with about 160 across the board. Previous owner had timing set way off also, now it is at 10 btdc and runs like a champ!
iMod
136
Centralia/Chehalis
Here's mine when I still had it a month ago. It's a JDM 7MGE, it wasn't anywhere as clean as I wanted it to be but I could never find time to clean it up properly.
These were taken the day that I painted the Y-Pipe.
