n/a auto to turbo 5 speed swap questions
Supraflymk3
Supraman
Dec 17, 2005
272
Neenah, Wisconsin, United States
Ive searched and read a bunch of write ups on this but I still have a few questions.
My car is a 91 n/a automatic. Has ABS no TEMS. I have the engine completely built and in the car. I still need a r154. I bought a hacked up early 89 manual gte harness. I was able to use the n/a harness as a donor for the dash plugs. I believe I have mostly everything right but I only have one wire going to the b2 plug and I feel like that shouldn't be. I eliminated any wires that had to do with a/c or auto tranny. I also repinned the connectors as if it was a manual. Will that pose a threat?
1st- Any info on what wires should be going to b2.
2nd- does my car have a tucked away plug for the clutch start switch?
3rd- I eliminated cruise control too; can I remove the speed control module?
4th- trying to eliminate unneeded wires, just wondering if I can get rid of the 3 plugs that would be right in front of the auto shifter, blue, white, clear.
Thanks in advance.
jkendall86
161
4
Salem, Oregon
I also have a 91 auto shell that was converted to manual. From my searches, if you want to all the neutral start you should find the wire from the ignition switch that goes to the starter. Cut that wire and place each end onto the neutral start switch.
contact me via text...503-930-7268
