my Story !!
rocketman
57
md
Im not new to the supra game just new to this forum . Im from the baltimore Area and im a mechanic at a shop .
2 yrs ago i bough my friend 89 turbo targa wit blown head gasket for 300 wit 17 inch rims !! I have stock headgasket . So i took my time wit the build i got the head back together. I have ran into some problems .1 the coolant lines behind the intake manifold. . 2 the Vacum lines from the Egr .. i have a block off plates but after reading the 411 on cooler egt temps im gonna invest in a Egr soon . 3 What would the best step up i could go wit to get atleast 300hp at the wheels .So if any one reading this and has any 411 that can help it would be much appreciated ......Roc
s383mmber1
3,614
Somers New York
300 horses can be reached fairly easily on the stock turbo
Boost Controller
BIC DDP
3 inch exhaust
Intake
Intercooler
And good stock turbo
Your right around 300 if not more to the wheels.
There was a guy on here the other day who reached over 300 with just intake exhaust but with an AWESOME tune!
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
its from bicperformance.com, best bang for your buck on the supras. oh and 350 whp is attainable on a stock ct. i didnt say for how long tho :rofl:
rocketman
57
md
ok i gotcha .. just bolt on for now but a rebuild for serious hp ..
Would i Gain any extra hp from Changing my manifolds.. and a Elbow?
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
get yourself a bic divorced downpipe, 3in exhaust, intake, manua boost controler and a high flow cat, ide retorque the headbolts to more than factory settings :)
rocketman
57
md
im gonna take pics friday finish up my car.. and get tags then im gonna find a dyno.. I think Eip or atlantic has a Dyno.. But i still need to add those water lines behind the intake .. then thats all she wrote
americanjebus
Mr. Evergreen
wa.
rocketman said:
i forgot to mention i got arp headstuds..
You didnt say how much torque you have on them though, the general consensus has been that the MINIMUM torque you should be putting on your hg is about 74-76 ft/lbs the stock 54ft lbs is NOT good enough if you go by the book.
How many miles are on this car??? How is the shaft play on the turbo? Does it smoke on deceleration?
Its easy to make power on this car but i just dont want to see you go for hp on a motor that wont handle it. From what i have read those are the main things i would worry about.
btw welcome to the forums.
antman
632
TN
welcome,
damn what a steal! glad to see you brought her back.
if you want it to last longer, make sure you do alot of research. this site is your friend and home to alot of us now.
ANT.
rocketman
57
md
yea im gonna take pics tonight when i work on it.. im gonna retorq the bolts and get the special nuts for the valve cover gasket im gonna use K&n oil filter wit lucas.. is it good to use a oil additive ?
rocketman
57
md
aight so i see now.. just the Basic bold ons .. um.. one other thing... ...... the cars sat so long is the a possibilty of the bottom end going bad.. should i take the pan off and check the bottom end
SupraDread
153
New York
Do all the fluids if possible if the car had sat 4 along time. Your a tech so u know the deal. The same applies to your MK u lucky devil. 3 hondo is all u paid? Daammmm that's goooodddd. Welcome............... u tapped into the MK FORCE Roc use it wisely. Anyway me and the fam plan on moving to MD next summer if all goes well, so keep in touch I would like to know a fellow MK owner in MD.
